neweuser
neweuser's Avatar
02.16.2007, 12:31 PM
OK. With 4s and an 8xl, if you are running a center diff? On the slipperential I gear it 16T pinion with the Revo spur. I run the UE 1/8th diffs. the center diff in the slipper is the Hot bodies I believe. Not too fast, but fast enough for a track...this is in a gmaxx.
If you were using the tranny, you could gear it 18/51 mod 1....mod 1 is all I ever used, so not sure...
