jnev
jnev's Avatar
02.22.2007, 08:27 PM
Welcome to the forums.
The castor blocks from FLM are very strong. Even if they do break, FLM has a great warrenty and you'll get another set for very cheap, if you even do break them. I'd suggest hinge pins from Lunsford racing. You can get a set here:
http://www.lunsfordracing.com/mm5/me...Code=TRUC-TRST
I am sure you can get them from Tower Hobbies as well.
bi_eep
02.22.2007, 10:05 PM
I just realized i bought the wrong caster block....it's for the nitro stampede i have the xl5 electric. I know i could get nitro hubs and run the tires that go with it but i just ordered rpm hub carriers...
http://www2.towerhobbies.com/cgi-bin...&I=LXNY89&P=ML
Is it possible to run these hubs on the nitro caster block with the stock hinge pin?
I've emailed mike about my situation. I sure hope we can get this resolved.
