jhautz
jhautz's Avatar
03.03.2007, 02:47 AM
I just noticed some things I missed the first time.
It stores the highest temp so after a run you can plug your little programing box and see how hot it got. That is friggin sweet! No more guessing on the temp.
Built in switching BEC good for up to 30V input! About time someone did this. Having a separate UBEC is a PITA! To bad its 5.5V instead of 6V, but built in is still a plus IMO.
More than 32 steps for Adjustable Current limiter. Talk about being able to fine tune the acceleration. (32 steps might actually be overkill)
Velocity Responsive Braking System, which adjusts braking strength proportionally to the speed on the vehicle. (Sounds cool.... I wounder if it actually works)
It looks like a 25mm fan would fit nicely on the heatsink. Probably screw right in between the fins.
The more I read about this thing the more I like it!
Anyone know when its due out? This might be worth a look see.
http://rcforum.co.kr/news/entry/New-...-system-Plasma
to make it...
or break it...
Silent...But Deadly
