revo acting up...
t-maxxracer32
t-maxxracer32's Avatar
revo acting up... - 03.06.2007, 01:32 PM
hey guys i posted a thread a little ago saying how i got the revo... well its not exactly working like i had hoped. here are some problems
the tranny keeps coming loose (last time it did all i did was open it up and put it back together then it ran fine... and now it fell out again)
also the truck is going psycho when driving it. like im getting some crazy interference.
very bad range
not exactly going when i floor it.
pretty much something is wrong with the receiver/transmitter and i needa find out how to fix that tranny problem (i have the emaxx tranny)
thanks for your guys usuall help!
Last edited by t-maxxracer32; 03.06.2007 at 01:36 PM. Reason: had revos instead of revo..
03.06.2007, 02:02 PM
Are the tranny screw holes stripped? If so, I'd just get new a tranny case - it might have simply been put in and taken out too much before you got it. After all the threads are only plastic...
Brushed motors can be noisy because of the arcing of the brushes. I would move the radio as far away from any high current wires and the motors as possible.
t-maxxracer32
03.06.2007, 02:05 PM
no there not stripped.. i screwwed em in as tight as they can go. they wouldnt go anymore.
and ill try and reroute the the receiver as much as possible.
BlackedOutREVO
03.06.2007, 02:12 PM
are u running a ubec, or a rx pack? and what kind of radio are u using?
t-maxxracer32
03.06.2007, 02:17 PM
no im not running one yet...
and im using the jrsx3 system
BlackedOutREVO
03.06.2007, 02:23 PM
how many cells do u have???
wrap ur rx in tin foil a few times so there a bunch on it, its cuts down interfearence so less glitching... helps me, but i went to specktrum, no probs now :D
t-maxxracer32
03.06.2007, 03:02 PM
i dont have an rx yet. (an rx is a receiver pack right? lol...)
or does that mean wrap my receiver in tin foil?
thx
BlackedOutREVO
03.06.2007, 03:22 PM
reciever in tin foil..
rx i reciever
skellyo
skellyo's Avatar
03.06.2007, 03:37 PM
Also, do your motors have capacitors installed on them? If not, that could be a huge contributor to your glitching problem.
BlackedOutREVO
03.06.2007, 03:44 PM
yeh thats true also, forgot about those lol
use 2 caps if u dont, on each motor
t-maxxracer32
03.06.2007, 06:32 PM
where can i get these "capacitors" you talk of. boy i wish i was electronically advanced!!
radio shack haveem? if so a link would be coo! i could pickem up after work!
thanks as always guys
skellyo
skellyo's Avatar
03.06.2007, 07:03 PM
These should do it:
http://www.radioshack.com/product/in...entPage=search
On each motor, you'll want one between each terminal and the motor can as well as one between both terminals.
t-maxxracer32
03.06.2007, 08:43 PM
so wait how many do i need?
Sylvester
Sylvester's Avatar
03.06.2007, 08:52 PM
2 on each motor.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
Mike.L
Mike.L's Avatar
03.06.2007, 08:55 PM
your going to need 6. Or 4 depends how badd the glitching is. I'd prefer 6 always.
  Send a message via MSN to Mike.L
