BP-Revo
BMW M Power!
BP-Revo's Avatar
03.07.2007, 10:04 AM
captain - PHEW! :)
starscream -I don't know. Did you try messing with the programming?
There are so many throttle configurations and stuff on the Pheonix HV line its insane. You can adjust in hard cutoff, soft cutoff, current limiter (which cuts off when you draw too much for the ESC to support). You can set throttle type to remember your radio, automatically adjust endpoints each time you start it up, or have it "govern" where it translates throttle to a certain RPM and tries to hold that RPM regardless of load, etc. Then there is also start power, timing, etc. There is like 9 things you can program on that controller, vs like 5 on my little Mamba 25 (my only other CC controller).
I'm assuming it should work fine (hoping it will work fine - because there aren't many 8S controllers available for just 130 bucks!)
