felix
06.26.2005, 02:06 PM
Hi,
the HiTec is fine as far as I can tell. It's working at normal speed and turns the wheels without problems while standing still. Just happens in combination with the throttle problem.
I knew that the motor is really hot, I didn't know that it's too hot. ;)
The buggy is a GS Storm, the new parts are made of carbon fibre.
Some pictures can be found here
http://www.cx4.de/rc/storm01.jpg to http://www.cx4.de/rc/storm08.jpg
Most of them aren't too good, but you get a better idea.
I'm using BEC and the pinion (module 1) has only 13 teeth. So that's pretty low already. The car should be pretty light, about 2.8kg without batts I think..
I'll try to get some more info about the gearing.
