captain harlock
RC-Monster Captain
captain harlock's Avatar
03.12.2007, 02:38 PM
I guess it's a matter of flavour and preference.
Nice to meet you!
AAngel
03.12.2007, 02:47 PM
I've been considering both the Kokam and flightpowers because they are about the same price. I know that many have been touting the flightpowers here lately, but the Kokams are premiere cells in their own right too.
I don't know about GD, but from my perspective, the wire routing coming out of the Kokams are what I need, and from what I understand, the Kokam cells are of a safer chemistry and are more tolerant to overdischarging. The Kokam cells are also supposed to be pretty tough.
Since I've destroyed so many lipo packs, maybe a heavy duty pack is just what I need.
I'd also consider running two of the trakpower packs in series, but I don't want to sacrifice the convenience of the charger/balancer interface that I have with the tp 1010C and balancer.
BTW, can two of the flightpower packs be charged in series? If so, is there a way to wire up the packs with a more conventional balancing tap so that I can use my tp balancer?
glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.12.2007, 02:54 PM
Originally Posted by skellyo
Why would you buy the Kokam 4800's instead of Flightpower or Trakpower packs? They're pretty close to the same price even.
I can get a special deal on the Kokams...
How cheap can we get the flightpower 4900s? (4s)
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
skellyo
skellyo's Avatar
03.12.2007, 03:47 PM
I would think it wouldn't be a problem to charge them in series if you can put together the proper balancing adapter. If you know what sequence the TP balancer wants on the cell taps on the connector, you should be able to make one up yourself. However, you'll still need the Trakpower harness adapter for balancing since the pack uses a plug versus having a connector hanging out.
skellyo
skellyo's Avatar
03.12.2007, 03:51 PM
If you can get the Kokams cheaper than tower prices, you'll probably do better pricewise with them versus the Flightpowers. The 4S 4900 pack from atlantahobby.com is $244.99. I don't think you'll find it any cheaper than that. I've yet to find them available from a place that uses discount codes like tower does.
glassdoctor
TEAM FUSION
03.12.2007, 03:58 PM
Yep... quite a bit cheaper than tower....
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
skellyo
skellyo's Avatar
03.12.2007, 04:06 PM
Sounds like a good deal to me.
glassdoctor
TEAM FUSION
03.12.2007, 11:06 PM
Ok... well I ordered some Kokam 4800s so I guess we will see how they stack up. Now if I just had another $250 for a Flightpower... :)
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
glassdoctor
TEAM FUSION
03.12.2007, 11:14 PM
for the Flightpower junkies here: :D
Just wanted to post an amazing discharge graph of a Flightpower pack. The 5000 is by far the best of graphs shown on atlantahobby's site... it has an incredible voltage curve at 20-30c... where several other sizes of the flightpowers fall off.
http://www.atlantahobby.com/images2/...geCurve_lg.gif
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
skellyo
skellyo's Avatar
03.13.2007, 12:11 AM
The 4900's have the best discharge curve of the Flightpowers at 20C IMO:
http://www.flightpower.co.uk/core/da...0curve_600.jpg
vs. the 5000's:
glassdoctor
TEAM FUSION
03.13.2007, 12:16 AM
Cool.. a couple of the graphs didn't show up on the site.. I wondered about tehe 4900. (the site linked the 3300 graph which isn't very good)
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
skellyo
skellyo's Avatar
03.13.2007, 12:18 AM
A backdoor to the Flightpower 20C graphs, among other things:
http://www.flightpower.co.uk/core/da...ts/20C_Graphs/
skellyo
skellyo's Avatar
03.13.2007, 12:20 AM
Another handy chart showing size and weight of all the Flightpower packs:
http://www.flightpower.co.uk/core/datasheets/WXD.jpg
BP-Revo
BMW M Power!
BP-Revo's Avatar
03.13.2007, 12:21 AM
4900's are my next battery :D
I just gotta sell my current ones.
glassdoctor
TEAM FUSION
The 5000s do hold the capacity a little better at 20-25c but the voltage drops sooner at lower rates. Both are very good though.
I'm reading that the same Enerland cells are used in:
Flightpower Evo
Hyperion LVX
Polyquest XP
TP Extreme
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
