03.30.2007, 08:23 PM
4s lipo will be overvolting the fans by a little bit and may shorten their life. If they are typical 40mm fans, they only pull about 0.05A each. If so, you can read this to keep them at 12v.
BTW: You don't want to put the fans over the heatsink since the top is just plastic. For best results, the fans should be cooling the bottom.
