Finnster
KillaHurtz
Finnster's Avatar
04.03.2007, 02:02 PM
Originally Posted by skellyo
Actually, I do think they rate the 5700 for 3S or 12cells. It's just under 65k at 3S and just over 65k with 12cells. Keeping in mind that the Mamba Max motors are rated unloaded, it should be fine...but it's gonna get hot easier.
Here's a link to a recent thread about a guy using a 5700 on 12cells in a rusty and getting into the mid 60's:
http://www.rc-monster.com/forum/show...6643#post96643
Well, checking CC that is correct. I knew they always rated the 5700 as 3S, and the 4600 upto 4S, but I remember a thread awhile back somewhere where running 12 cells on the 5700 was considered borderline, as very good cells can push the motor upto/over the rpm limit, and it was safer to go down a bit. OTOH, people have run the 7700 on upto 8 cells, so....
Anyway, if the gearing is ~6 (like a 14/84) I don't see this as too bad. A thought was maybe the gearing is so low that the motor&batts aren't well loaded, so the rpms went over limit. but perhaps this wasn't the case then.
Was the slipper ok, or did maybe you strip the wheel hexes or something? running that much voltage w/ that motor getting that speed does not add up.
