Procharged5.0
Procharged5.0's Avatar
04.04.2007, 01:32 PM
I've found it easier with some diffs than others.
If you're using traditional diff cases & bulkheads there can be pressure exerted on the case laterally by the bulks when the bulk/chassis/shock towers assemblies are bolted together.
then you have to reshim to adjust for that.
In other set-ups, particularly the FLM hybrid bulks and the UE VBS this is non existant.
