MetalMan
MetalMan's Avatar
06.30.2005, 07:29 PM
There are a number of places that sell the adapters. This slop can't be taken out, since it is from the hole on the adapter to the smaller diameter of the axle.
If you do a 'Pede conversion, and use MIP CVD's, then you can't use the adapters since they have a larger diameter than the regular 'Pede axle. But, you could use dogbones and HPI axles, since the axles are 5mm.
