what length shaft for front center FLM chassis?
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
what length shaft for front center FLM chassis? - 04.08.2007, 03:34 PM
I know it comes with the shaft for rear, but what about the front? What shaft can i use, I do have the RC-Monster extended CV's, will the short one be the right length? Or do I have to use a slider shaft?
GorillaMaxx360
GorillaMaxx360's Avatar
04.08.2007, 03:45 PM
the short one should work 72mm
zeropointbug
Z-Pinch racer
04.08.2007, 03:54 PM
Great~! Are you sure then? Then at least those won't be completely wasted...
GorillaMaxx360
04.08.2007, 04:09 PM
i am pretty sure but let others chime in and tell you what they think.
ssspconcepts
ssspconcepts's Avatar
04.08.2007, 04:23 PM
This is the one that I used for my FLM setup and it fits perfectly (83mm assembled).
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXLSS8
ssspconcepts
04.08.2007, 04:31 PM
Here are my lessons learned from building my FLM E-maxx
zeropointbug
Z-Pinch racer
04.08.2007, 04:57 PM
K, thanks guys. I have no way of checking this yet, so this will have to wait another week or so. :024:
GorillaMaxx360
04.08.2007, 07:36 PM
very helpful info thanks
GorillaMaxx360
04.08.2007, 07:39 PM
zeropointbug i have asked this question before because i have a FLM chassis and i am pretty sure they told me 72mm. also 72mm is stock for the front the only difference in the gmaxx chassis is the extended rear the front is the same length same with the FLM chassis it is only extended in the rear. the 72mm should work because it is made to replace the stock part that is standard length. wait just to be sure or pm serum or one of the other guys that are high on the totem pole they should be able to help, but i am pretty sure it is 72mm that mike sells.
ssspconcepts
04.08.2007, 08:27 PM
That sounds right because the MIP coupler at the tranny output shaft is about 10-11mm plus the 72mm shaft equals 83mm. At any rate the MIP kit works. I personally would have liked to get a set of the T-Bonz (by TSAIS)center shafts...they are nice. They have a notched cross pin and c-clip to assure that they stay together. I use them for my drive shafts but at the time I was building, the T-Bonz center shafts were not available.
zeropointbug
Z-Pinch racer
04.08.2007, 09:25 PM
oh okay, yah that makes sense that only the rear shaft would be extended, just to keep things somewhat standard, and easy to adapt too...
Thanks again guys, I'd sure this will work then.
coolhandcountry
coolhandcountry's Avatar
04.08.2007, 09:48 PM
When i ran my flm chassis. I used the ue ti shafts. I used a 70 up front and a 105 in rear.
Peace!
Country
Help support the
Rc-Monster
Buy here
ssspconcepts
04.09.2007, 04:46 PM
Here is a PDF photo of the the center shaft (front) that I use with my FLM E-maxx chassis. It is the MIP kit I posted a link to yesterday:
zeropointbug
Z-Pinch racer
04.09.2007, 04:56 PM
I already have the extended steel shaft's Mike sells, I'm going to use them.
I also am using new MIP Shiny CVD's all around, Maximizer diff in rear, and older Kippster diff in front. I am going to get some Integy diff cases for now, I want to get some hybrid bulks eventually, OR some UE bulkless victories.
wallot
wallot's Avatar
04.09.2007, 06:32 PM
With stock diffs standard maxx stuff is OK but carefull with hybrids - > thanks to longer diff pinion + drivecup you need shorter dogbone. I have a temporary solution in rasing the transmission by about 8mm but Mike is making me custom dogbones.
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
