Aragon
04.12.2007, 05:43 PM
That's great news. Thanks for posting...
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
04.13.2007, 12:31 AM
Yah, I thought it should be posted. If these things are still giving this performance after that many discharge/charge cycles to basically 100%DOD everytime, then I can see them lasting much longer than any LiPo battery by a long shot.
My theory from what I saw from A123, was that the main thing that shortens the life of these is the temperature. They are rated at 95% retention after 1000 cycles @25 C. It gets interesting when you up the temp...
- temp: 45 C, 89% after 1000 cycles (5A discharge)
-temp: 60 C, 76% after 1000 cycles (5A discharge)
So it looks like as long as they are kept in a cool environment, they should last quite a while for RC batteries. Keep in mind, there has not been a high temp, high discharge tests with these cells. But my results show that they are truly superior battery technology in contrast to LiPo as far as lifetime is concerned. I did not, however, have an eagletree when I first bought these cells last year (a full summer full of hard running), but to me 2375mah vs. rated 2300mah after 100 cycles is very impressive non the less.
Also worth mentioning, when I first got them, I accidentally dead shorted 4 of them and literally blew off the tab on two of them (double tabbed though), but to my surprise, they were glad to stand back up and perform just as well as the non-shorted ones. :027:
Anyways, I hope this shows a bit of information to someone trying to decide between A123 or LiPo, or NiMH.
Cheers!
