04.13.2007, 11:24 PM
NP.
By tricke charge, do you mean the CV stage? It does add some Ah into the cell so I would keep doing it.
The starting voltage of 6.9v seems good. It's probably a little lower right after a run, but it drifts back up and that number looks fine. If you discharged deeper (NOT recommended), you'd probably be charging closer to 5Ah back into the pack.
