Joram
Nitro?? BL rulezzz
08.12.2008, 08:41 AM
There is only 20 euro's, yes the valuta here:p so i'm going to buy Truerc packs, BUT!!
I have a Imax B6 charger, it has an JXT balancer, but what balancer have the Truerc packs, they look the same, don't they?
the lipo on picture is 5s but that doesn't care about the balancer...
Greetz,
Joram
  Send a message via MSN to Joram
bl-is-future
bl-is-future's Avatar
08.12.2008, 09:11 AM
well you can proly specify the tap at the time of the order for custom packs but if not it will say in the description what tap it will come with and if it is not just than you can buy an adapter to be able to balance it.
azjc
08.12.2008, 12:28 PM
they come with Hyperion taps
Joram
Nitro?? BL rulezzz
08.12.2008, 01:22 PM
oké :)
Today a package from LiquidRC has arrived: Proline Commando Beadlocks, silver version
Tomorrow my Bow-tie's and LST shocks arrive, Friday my Savage X and FLM chassiskit:)
Greetz,
Joram
bl-is-future
08.12.2008, 01:23 PM
joram once it arrives you can send it all my way, ill take good care of it.
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
08.12.2008, 07:53 PM
If you are running on 6s an Feigao 11xl or 12xl is a good cheap motor. An 8xl will run stupidly hot. I have the 11xl but haven't been able to test it fully due to the MMM issue.
The 2 speed is useful though. When I first ran my car it was pulling a huge number of amps but the car was going into second really quickly. I adjusted the shift point screw so second kicked in later and it dropped the amp draw considerably on the second run. Due to the MMM failing though I don't think I was able to actually hit second gear though on the second run due to space limitations. So I don't know if when it hit second it would pull more or less amps then what it was when it was set to change earlier. My guess is it would pull a bit less.
Joram
Nitro?? BL rulezzz
08.14.2008, 04:51 AM
So, my Bow-tie's have arrived and my LST shocks too :)
Hopefylly today or tomorrow my Proline Desert Rat body arrives and my savage and flm kit too...
I open an other topic fot the building of the truck..
Greetz,
Joram
Joram
Nitro?? BL rulezzz
08.14.2008, 05:44 AM
another question..
If i want to lock my gear into 1st the only thing i have to do is not to let it shifting, so adjusting the shifting too late ???
I love big power so i want to lock it into 1st. 2-speed is nice but when shifting i think it will crush the plastic gears....
Greetz,
Joram
