hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
11.26.2008, 01:17 PM
Originally Posted by speedy View Post
is it impossible to make an effichent setup on 4s lipo ? in an e-revo ?
the 1515/1y works great on 4s. geared for 40+ its been one of the best set-ups I have used.
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
speedy
11.26.2008, 01:55 PM
No 40mph is waaay to slow for me :) i whan't min 50mph !
VintageMA
VintageMA's Avatar
11.26.2008, 02:01 PM
Except for efficiency and a bit less heat I don't see any reason that 4S is not a viable option in the E-Revo. Just make sure your batteries (probably 4S - 8000mAh best) can push the higher amount amps required for the lower voltage setup.
My peak with an Eagle Tree with 6S and a 1515/2.5d in the e-revo was about 2200 Watts. That's about 100 Amps on 6S - means you'd be looking at about 150 Amps on 4S.
I find that even pushing the constant C rating on lipos the batteries get pretty warm, so for a 4S 8000mAh pack I would say something with a TRUE 20-25C rating at minimum.
“Everyone has a right to be stupid; some people just abuse the privilege.”
speedy
11.26.2008, 02:31 PM
maybe i scould put an 1521in there and gear it 22/54 ?
starscream
RC-Monster TQ
starscream's Avatar
12.06.2008, 04:43 PM
1515 3D works great on 6S
Ha Ha
The Flashlight Strikes Again...
11.27.2008, 06:47 PM
That motor would pull more amps, epecially if you geared it pretty tall for higher speeds- it may produce more torque, but it'll work the batteries even harder (unless my thinking is way off the mark).
I'd say stick to 4s lipo & the 1515 1y, just buy decent batteries with good specs- zippy blue bricks or some nice Enerland 25c items. If you could stretch to the newer Elite 35c lipos, you'd be happy as larry* with the results.
*English expression, not refering to larrydino.
11.27.2008, 07:16 PM
"Your mom is a blue brick."
That was my sense of humour. Told you i have one.
11.27.2008, 09:20 PM
The epicness of your fail is matched only by your lack of comical talent...
My mum looks more like an old leathery creature- too many years sunbathing I think....
11.27.2008, 10:35 PM
Reminder: I have a Neu 1515/2.5d that I'll let go of. Either sell or trade for a Neu 1512/2.5d...
speedy
11.28.2008, 04:51 AM
hm.. maby i'm crayzy but would it be possible to upgrade the driveline in an e-revo so it will handle an 1521 motor on 6s lipo? that would make my e-revo crazy fast and strong !!! Like 75mps topspeeds and backflipi'n wheelies !
Would a mmm handle an 1521 motor on 6s ?i'm going to use an ex fan and u-bec !!
Unsullied_Spy
Unsullied_Spy's Avatar
11.28.2008, 05:21 AM
Convert it to run 8mm axles (and center shafts), run RC-Monster hybrid diffs with Truggy diffs, and Tekno RC 17mm/8mm axle conversion should do it. 75 MPH top speed should be attainable with either 1/8th scale foams or HPI Phaltline tires and some serious gearing (Mod1/Revo gearing should suffice).
I would use a stock MMM, the external fan would definitely void the warranty and I'm not sure about the BEC. It should handle it just fine IMO, I'd ask Castle to be sure but I wouldn't worry.
azjc
12.06.2008, 09:52 AM
tires will be your problem, if you use solid foams you will have a much easier time going that fast
stmoi
12.06.2008, 09:17 AM
What about 1515 1.5Y? Less amps, more runtime... Could this motor work fine on a 1/8MT with 6S?
I was going to buy this, but now I have to decide between 1.5Y & 2.5D....... I do not want to run toooo fast, and I do not know if my batts are capable to handle enough current (Zippy-H 5.000 20-30C). I believe the 1.5Y is perfect for me, what do you think?
12.06.2008, 02:03 PM
1.5y on 6s is a great setup. Better than a 2.5d or 3d IMO.
Unsullied_Spy
12.06.2008, 07:17 PM
The Y wind motors are more efficient than the Deltas, and since the 1.5Y isn't too much lower KV than the 2.5D IMO it would work very well.
