Superemaxx89
03.08.2005, 02:11 AM
i see your reflection!
That thing is HUGE!!! It looks like an airplane jet!
Can the 9918 handle the plettenberg bigmaxximum on 16 or 18 cells?
if your worried about weight why not go with lipo?
Chase023
Chase023's Avatar
03.08.2005, 02:22 AM
I don't think the 9918 is designed to handle 4 Pole motors which are a bit harder on controllers. I believe the 9918 is designed to handle up to 18 cells but not a Maxximum or a BigMaxximum. I could be wrong but I think the 4 pole motor is too much for it to be reliable.
Well I was really never worried about the weight because I wanted just raw power for this project and didn't care about handling just wanted power but now that I weighed 60 cells, its like 7+ lbs LOL.. Tho I would go Lipo which I would need 10 Cells per motor so I would need 20 Lipo cells but the config I need doesn't fit, unless I can get a custom designed lipo batteries. I asked Thunder Power batteries about it many times but no luck. The dimensions I have to work with is about as long as a normal 6 cell stick pack so I could theoretically lay down 15 cell per level which would line up 5 cells per column and 3 cell rows.
Embrace the Speed!
 Send a message via ICQ to Chase023 Send a message via AIM to Chase023
Superemaxx89
03.08.2005, 02:31 AM
so would a bigmaxximum fit in a stock emaxx pretty easily? What esc would i need for 16-18 cells?
Chase023
Chase023's Avatar
03.08.2005, 03:05 AM
BigMaxximum in a Stock, Yes it would but you will be limited on what pinion choices due to the stock motor plate.
Well Plettenberg recommends a 18.97KW so anything near that spec should be fine.
Embrace the Speed!
Superemaxx89
03.12.2005, 08:30 PM
so does anyone know if i can run 18 cells on a 9918-8xl combo?
18 cells
HotnCold
HotnCold's Avatar
18 cells - 03.12.2005, 08:36 PM
Yep - no problems mate....
Hows that "Hope and Change" working out for Ya???
