Go Back   RC-Monster Forums > Support Forums > Unlimited Engineering
Stobe slipper tip
rchippie
rchippie's Avatar
Stobe slipper tip - 04.24.2006, 08:31 PM
This is a tip for anyone using the strobe slipper. If you look at your (BLACK) diff ring mounting plate you will notice there is a reasesed section on each ring plate. This allows your bearing to slide back & fourth after some time. Simply put a few shims on each side of your slipper, enough to fill up th reasesed section. This keeps you bearing centered in your slipper & helps keep your slipper from wobbleing. This directions are on the strobe site. I just wanted to make sure everyone knows this tip.
REAL MEN RUN BRUSHLESS
killarevo
05.09.2006, 11:44 AM
what is the strobe site?.......thanks
neweuser
neweuser's Avatar
05.09.2006, 01:15 PM
If you are looking for the slipper clutch parts from there they are also out of stock of everything...
killarevo
05.09.2006, 03:03 PM
so what is the site address?......thanks
neweuser
neweuser's Avatar
05.09.2006, 04:59 PM
I believe they ony use distributors
coolhandcountry
coolhandcountry's Avatar
05.09.2006, 06:33 PM
www.strobe-rcracing.com
This I believe is it.
Peace!
Country
Help support the
Rc-Monster
Buy here
killarevo
05.10.2006, 09:01 AM
thanks for the info!
cabking
05.10.2006, 05:30 PM
Does anyone know what the blue stuff from the sprong is called?
