Sammus
Sammus's Avatar
04.25.2008, 07:50 AM
Originally Posted by tom255 View Post
Idea was let motor spin a litle bit, it mean that clutch not engage, like Idle on Nitro motors. I noticed that if motor spins about 10s with this ESC and you hit full throttle it spins up instatnly
And if speak about ESC even if program soft start setting to HARD it still spin up slowly, no chance to drift or correct trajectory in air
Yes this is right. The only options (See on the card) are "very soft", "soft" and "normal". Even on normal there is an extremely noticeable and frustrating delay. If you keep the motor spinning inside the clutch it may help, thought I think this isnt good for the ESC because of how they limit the rpm.
