New motor or repair Kit? 2200kv
togepipro
New motor or repair Kit? 2200kv - 03.07.2011, 09:16 AM
I break the rotor magnets of a 2200kv in pieces running in the street, the motor was in a Savage(TCS)1/5. New motor or repair Kit? I ask because the motor smell a lot burned.
New motor
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
New motor - 03.07.2011, 09:49 AM
I would think that a new motor is in order. From what you described rebuilding this motor would more than likely end in disaster anyway, so it would be my suggestion to just order a new motor and double check your setup for issues. Why did the motor fry to begin with? Maybe a better/bigger motor is in order as well for the size of your vehicle. Is the ESC still any good, or is that suspect as well? Looks like you have some homework to do so you can get this thing setup the right way to avoid buring up more electronics. Good luck with that.
SUPERMAXX YOUR LIFE.
togepipro
03.07.2011, 05:18 PM
It burned because I continue use it after I hear a grinding sound, I was thinking that the sound come from the transmission, never goes in my mind that the sound come from the motor. I'm going to borrow a motor to check is the MMM is ok, but 0 smell of smoke on the MMM and the start up is ok.
So, I'm going to start looking for a 1518 or 1520 on ebay... I like to put a 1717, but is not possible with mayor modifications or someone know how to resolve the motor mount issue ?
George16
Supermaxx
George16's Avatar
03.07.2011, 10:26 PM
Just buy a new motor.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
DrKnow65
DrKnow65's Avatar
03.09.2011, 09:49 AM
Correction, "Just buy a -NEU- motor" :-)
togepipro
03.09.2011, 02:05 PM
I'm looking for a "cheap" 1518 or 1520. I should buy one when castle have it =(
DrKnow65
DrKnow65's Avatar
03.09.2011, 02:10 PM
Look for a used one on RCGroups.com in the for sale forums.
Or you could pick up a clearance NEU 1515 right here on RCM :-)
Kirkinsb
Brushless All The Way!
Kirkinsb's Avatar
03.09.2011, 05:57 PM
You will LOVE the 1518 motor. it is all I run now. Gear higher and it runs stronger than the 1515 in any of my vehicles. Runs cooler and won't blow the rotor like a 1515 does when it gets hot. I have never blown a 1518 because they simply dont turn as many RPM. I have sure blown a couple 1515 rotors....That is my experience with the 1518.
togepipro
03.09.2011, 06:36 PM
OK, so a 1518 will be, + with the 1518 i don't have to cut the TVP's, only make the motor mounts bigger.
Thanks for all.
togepipro
03.10.2011, 08:15 PM
Thanks for all.
I buy a 1717 instead of the 1518...
What do you think guys will perform with these specs ?
Will get hot ?
The roll out pinion is 15. I'm going to use 18.
Differential Ratio: 3.2222222222222223
Transmission Ratio: 2.215277777777778
Other Ratio: 1
Spur Tooth Count: 44
Pinion Tooth Count: 18
Total Voltage: 22.20
Motor KV: 1580
Tire Diameter (inches): 6.69
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 2.44 : 1
Total Ratio: 17.44873 : 1
Tire Circumference (inches): 21.02 inches (533.84 mm)
Rollout: 1.20:1
Total Motor Speed: 35076 RPM
Vehicle Speed: 40.01 mph (64.27 km/h)
Effective KV Value: 1580
KT constant: 0.86 oz-in/A
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
03.10.2011, 09:50 PM
The 1717 will run very nicely on 6s but the biggest problem will be getting it in the truck and getting a decent gear mesh ?
Heres what I did
Will need a RCM 3.3 Revo conversion motor mount and look here.
http://www.rc-monster.com/forum/showthread.php?t=28168
togepipro
03.11.2011, 12:24 AM
Heres what I did
Alza Racing sells a 49.50MM motor mount. I need to cut a little bit the rear of the right tvp. But I think is going to work. I put pics when Finish.
