Sidewinder 8th feedback
Pdelcast
Pdelcast's Avatar
Sidewinder 8th feedback - 06.16.2014, 11:47 AM
Looking for any comments, concerns, etc. about the Sidewinder 8th.
Anybody here tried it?
Thank you!
Patrick del Castillo
President, Principle Engineer
bdebde
That's All Folks!
bdebde's Avatar
06.16.2014, 03:04 PM
I have been thinking about trying one... any one else tried yet?
Pdelcast
Pdelcast's Avatar
06.25.2014, 01:24 PM
Was really hoping to get some feedback here...
This is really a nice ESC and is almost a direct replacement for the Mamba Monster.
Please post your experiences here.
Thanx!
Patrick
bdebde
That's All Folks!
bdebde's Avatar
06.25.2014, 03:03 PM
Was hoping for some feedback too.... guess I will have to be the guinea pig!
A RC Dude
A RC Dude's Avatar
07.01.2014, 12:35 PM
I have one, something is wrong with the start power and I just shipped it in. It ran perfectly at speed (above 3mph or so) but below that there was barley enough power to get the truck moving, much less spin the tires as it did from 3-20mph easily. It did this with two motors.
And I dislike the removable RX wire...I had to bend the pins around and use a zip tie to hold the wire and get it to make a good connection during a run and not come unplugged...
I'm sure the first problem was an error in manufacturing on mine, as for the second, i'd rather have a female rx plug than the three pins that fit too loosely
Fix those two things and it'll be golden
Pdelcast
Pdelcast's Avatar
07.03.2014, 02:46 PM
Thanks for the feedback !!
Hadn't seen any issue with the removable RX wire yet -- that's interesting that you are seeing it come loose. I'll have the engineering team here look at that and see if there's anything we can do to fix the issue on this side.
The start power issue is probably just that -- start power is set too low for your particular motor. Have you tried bumping it up?
Thanks!
Patrick
A RC Dude
A RC Dude's Avatar
07.14.2014, 02:52 PM
Thanks!
Patrick
The start power is all the way up and it did in one 3 65C batteries and 2 motors...still can't go anyware below that speed. Castle has is and i'm working on getting my receipt to have it replaced (LHS closed down)
The removable rx wire would be a defect in the thickness of the pins or inserts in the wire plug, It was also one of the first run ESC's i think to where the problem may have been fixed already. I solved the wire problem by bending the 3 pins different directions so they hold pressure and then used a zip tie to prevent it from coming loose
Pdelcast
Pdelcast's Avatar
07.14.2014, 03:01 PM
Can you post up the setup you are seeing difficulty with? We just haven't seen an issue like this before. I'd like to have our engineers see if they can reproduce in the lab.
Thanx!
outlaw
Castle addicted
outlaw's Avatar
07.18.2014, 06:08 PM
Not avalible in germany yet,
but as soon i have it i'll post my feedback
kind regards
Mirko
Brushless motors have to be green ....
A RC Dude
A RC Dude's Avatar
07.20.2014, 09:29 PM
Thanx!
I tried different firmware and settings and it still did it. I already have my new replacement back so I can't look up anything anymore. I can send you my packing slip information if you want to try to find my old esc and play with it since you guys already have it there.
And back to the wires pulling out, you guys already fixed it, the new version has tabs to clip the wires in, my first one only had the friction of the pins fitting into the slots holding them in.
Here is the new one:
Originally Posted by phildogg View Post
Receipt? Its a brand new system only out a few months. Don't seem like you would really need one. anyway I have thought about getting one for a slash 4x4 build I started.
My thoughts exactly, little bit of a hassle going through hobbytown headquarters to get a recept (since the local one shut down) but it's done now lol
phildogg
phildogg's Avatar
07.19.2014, 07:33 AM
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
phildogg
phildogg's Avatar
07.22.2014, 09:28 PM
esc looks good. lmkk how it runs. I might pick one up for slash 4x4.
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
A RC Dude
A RC Dude's Avatar
07.25.2014, 12:51 PM
I'm actually selling it. while I sent it back for repairs I got a ran a MMP instead and am just sticking to it for now. I got the Sidewinder 8th ESC for my SCT (140 degrees max racing without a fan). Assuming that one problem only me had, it's a great ESC
