Thread Tools Rating: Thread Rating: 28 votes, 5.00 average. Display Modes
Jahay
05.05.2011, 08:33 AM
i was reading some descriptions, but i am unsure as to what is accurate!
I was looking at the Leopard 4082 1000kv or 1250kv (42x82mm can)
http://www.offshoreelectrics.com/pro...o-4082&cat=148
But it says that they should only run 25,000-35,000 rpm???
It is a little low right? Because on 9s a 1250kv motor is spinning at 41,000rpm... That seems acceptable right?
DrKnow65
DrKnow65's Avatar
05.05.2011, 09:32 AM
Those RPM suggestions are from OSE (off shore electrics), and seem to just be a very general guide line...
In my experience a tame setup is 25-30k, a performance setup is 30-40k, and a screaming setup is 40k and up. I think the higher the RPM the motor peaks at the more aggressive the acceleration is getting to that RPM. I've settled in at around 38-40k for the best compromise of power and run time for most of my rigs :-)
kievyu
05.05.2011, 12:43 PM
i am very tempted to try one of the leopard 1000kv motors but i am struggling to believe that when the can is smaller than a castle 1520 1600kv motor, can it really deal with the stress of running 10s???? Maybe it can? But i think i will give it a go and test it at some point...
4082/2.5y for 9s ... 4082/3y for 10s ... rpm don't over 50000 !
Overdriven
Destroyer of Tires
Overdriven's Avatar
05.06.2011, 06:40 PM
Part of the difference in diameter is the fins of the CC motor. The rest, who knows wihout internal dimensions on both. Either way the difference in size is too close to have much of an impact. Lack of fins, construction and materials differences would have a bigger impact.
nuz69
nuz69's Avatar
05.06.2011, 07:56 PM
The 4082 is equivalent to a Castle 1518 I think...
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
Jahay
05.07.2011, 05:08 AM
considering i already have 9s worth or lipos... i would most prob go for the 4082/2.5y for 9s
Im just shocked that the size of the can is of that of the 1518!!! Smaller than a 1520! i dont know how well it will be able to cope with my heavier truck... only one way to find out i guess haha
Just out of curiousity... if a motor fails and implodes, would and esc blow too?
nuz69
nuz69's Avatar
05.07.2011, 05:18 AM
It depends if you stop pushing the trigger in time I think ^^
x-y
x-y's Avatar
05.09.2011, 11:49 AM
I use the leopard 4074 2150kv + 3s + ezrun sc8 in a buggy of 4kg in races of about 15min ........... the temperature of the motor is great ..... never up 55cº
I have neus and xeruns and the temperature of the leopard are lower than the others ....... using the correct gearing ;)
leopard 4282 + 9s = will kill the motor sure :p
if you search use this motor in crazy projects I recommend max 4-6s
SWORKZ BE-1, LEOPARD, HOBBYWING, GENS ACE, SANWA VX, FUTABA 3PL, MBX5R/T, RB5SPSL, FG MONSTER, TC5R, 808E, HYPER8, TF5, ZX5, NANO-TECH, HYPERION, 620DMG, ECO6-10, TEAM-IHOBBIES
Dj_Sparky
05.09.2011, 12:57 PM
2150kv on 3s is pretty tame, and I don't think any motor whatsoever would get hot with that kind of setup and right gearing.
Nixpus
05.09.2011, 03:40 PM
Regarding the RPM limit from Off Shore... I'd guess its a matter of the application rather than the motor. Think about it... even 25k RPM is mind boggling for a propeller... you need the right prop or you'll just make alot of bubbles :)
Hope it made sense?
x-y
x-y's Avatar
05.09.2011, 08:25 PM
for races in 1/8tt you dont need more power than 3s +2150kv ............ in my races people use 2200+4s and 2650+3s and the speed is the same
this is my last race ....... I used a xerun 4274 and the temperature arrived at 65cº....... using the leopard 4074 provably will be 50-55cº
http://www.youtube.com/watch?v=Uze8fsIa2LY
nuz69
nuz69's Avatar
05.10.2011, 10:12 AM
On your track, maybe 3S + 2200Kv is enough... But in classic euro tracks, 4S 2200Kv with high gearing is requiered ^^ ~40-42mph.
Dj_Sparky
05.10.2011, 07:32 PM
Very nice, but I wonder how hot it would get if you pushed it? With, say, 6s and bashing (Not racing obviously..)
Still, the fact that it's colder than Xerun is quite impressive. Xerun's are getting pretty well known for quality, and Leopard is much cheaper than that Xerun motor.
leopard 2000kv 4082 motor
bundyracer1
leopard 2000kv 4082 motor - 05.15.2011, 09:19 PM
Hi everyone, i was thinking of getting a leopard 2000kv 4082 for my brushless truggy and using it on 4s. The motor will be bought off ebay. I had a look at leopards website and they dont have a 2000kv 4082 motor. Is this motor the 2000kv 4082 only exclusive to kershaw desings?? help will be much appreciated. thanks
matt
nitrostarter
nitrostarter's Avatar
05.15.2011, 09:39 PM
Hope it made sense?
That's exactly right, the RPM limit on OSE is regarding boat applications.
N. Rustler conversion
