speedracer1129
12.04.2008, 10:29 PM
Originally Posted by cheesecake View Post
you buy a used motor from me... come on here post your wonderful setup then when you run the motor over what its max rpm is and after you run it for more then 30 seconds in your paypal claim you want your money back......
you ran 1 run you had the carrier fail that would cause an abrupt shock on it and damage the bearings in the motor. i should not be responsible for you not running the motor within its specs. i ra the motor on 5s without any issues.
there was nothing wrong with the motor when i sent it and your abuse on it should not make me responsible.
Ok. This the last time I make a comment to you on this forum in my thread. At no time did I drag anyone's name or say don't deal with such and such as I think things should be dealt in there proper place. That is why I opened a "dispute", not a "claim" through Paypal as it is the proper thing when someone feels they have possibly been part of a bad transaction. With that said, by you coming on here and throwing "dirty laundry" for everyone to see I take it personal as I feel it makes me look bad whether true or not.
SOOOOO.............. You stated the motor was in excellent condition. You stated that it only had a "couple" of races on it AND with fans! You also stated that you were running it with fuel tubing around the wires to protect them from possible shorting. Well here is the funny thing. I found your thread in RCtech and you communicated with me on the 25th of Nov. Here is the post with your description:
http://www.rctech.net/forum/r-c-item...a-monster.html
Now how is it that I found a thread here on Monster
http://www.rc-monster.com/forum/showthread.php?t=16522
dated 12 days prior to the RCtech thread stating the motor had 3 races PLUS practice? How is it there is no pics of the fans or a fan mount you stated? Most importantly, why does the Monster thread show the motor wires with NO tubing? Why did you go through the headache of unsoldering whatever connectors you were using, put fuel tubing over the wires, and put new connectors and cover the entire wire with heat shrink?? What were you hiding????
Next time, don't be so quick to try to make someone look stupid when you are the one that ends up.........See you at Paypal and don't post on my thread!!
