Serum
Serum's Avatar
04.30.2007, 03:51 AM
anyways. im thinking of a setup along these lines
-mikes custom mount (if it will work for the motor that ima get and if it will work for the vantage chassis (should i hope..)) Mike can make it for the motor you want
-neu 1515 1.5d
-quark 125b
-cnc heat sink for quark
and for batteries i will be using my 6s1p a123 cells and 16 cell tenergy packs. i might end up buying 2 more 6s packs and stick withonly those but for now this is whatim working with. i will not buy lipos because
-they are expensive
-they wont withstand my shitty driving
-they take a long time to charge (ik the other 8 cells will to but i already have those!)
Good reasons not to buy lipo's but you could consider trakpowers
anyways... i do have a couple questions about the setupd
1. with the neu motor will i get
-better run times? compared to what? it is an efficient motor, but so is the 1950. DIfferences in runtime between a neu and an 8XL will be minimal
-cooler temps? Compared to what?
-less cogging? cogging mostly depends on the controller
-more reliablity then lets say... an 8xl? No, reliability is not an issue
-less rf? if this has to do with the motor... No, it's a 4 poler, theoritical it would produce more noise than a 2poler
2. with the quark 125b
-less cogging? idk if this has anything to do with the esc... yes, s
moothest esc available
-less rf? if this has anything to do with the esc... Depends on your wire routing/setups style
-will i notice a difference than the 80b? or the cc esc? yes, the 125 is more suited for MT's. the 80b is too light
-is it worth the money? IMO, yes, but that depends on you
3. is the neu a better choice then the 1950? i honestly do not know any difference other than price... fill me in!! yes, i think it is. Too bad you need a more expensive controller with it though
4. what is the difference between a high dollar setup (125b and a 1515) and a low budget setup (cc esc and a 8xl) the 8XL will be less efficient on partial load, and will get hotter because of that. the 1515 has got more torque as well. the quark is the smoothest esc available, but the MM is close. I don't recommend the use of 6S on both controllers though.
basically i want the most baddass truck possible. well kinda... i am willing to spend money. not waste it. i will be honest. speeds over 45 scare me with a rustler so for a 1/8th 4wd mt.... idk... (ik its not actually 1/8 but its technically that size... i think...) yes, 40mph is more than enough for bashing an MT, both setups will suit your needs, and again, 5S is enough
ok well that was definetly well spent hour... sheesh...
sorry for the long post....
i appreciate it alot though!!
Sorry for not replying any sooner.
thanks for any help guys!
anytime
