jhautz
jhautz's Avatar
05.09.2007, 02:08 AM
Heres the picrures of what I did. Basically a .375 alluminum plate with 4m holes drilled and tapped in the bottom edge. They line up with the nitro motor mount adjustment holes in the stock savage plate. Then I took a piece of scrap CF angle I had and mad a bottom for the mount that goes under the motor and holes to allow it to be fatened in the other 2 stock motor mount adjustment holes. Accross the front to hold the motor I used a couple G-maxx motor mount plates I had sitting around. They are doubled up and should be plenty strong considering the motor is sresting on the bottom CF plate so its supported all the way back.
Its a tight fit but it works. Not a ton of room for adjustment under there. The motor can is all the way against the side chssis plate and resting on the bottom mount. I wanted to use a 24T oinion cuz I'm running a 2 speed and first gear is low, but it wont fit. The biggest gear I can fit is a 20T, maybe 22T but I dont have one to try.
Anyway, hope this helps.
http://i66.photobucket.com/albums/h2...z/CIMG1875.jpg
http://i66.photobucket.com/albums/h2...z/CIMG1876.jpg
http://i66.photobucket.com/albums/h2...z/CIMG1880.jpg
EDIT: Thanks Serum.
to make it...
or break it...
Silent...But Deadly
