wallot
wallot's Avatar
06.20.2007, 08:32 AM
for mounting motor (actually all over my truck) I started to use AP hexscrews (from hexscrews.com) they dont get loose as fast as standard 12.9 grade screws and i did not want to use loctite
i use M3x8mm as the motor mount has like 4mm a 4 mm are enough to hold the motor (if i remmember Neu manual says something about max 5mm into the motor)
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
