GorillaMaxx360
GorillaMaxx360's Avatar
10.08.2007, 12:39 AM
BP Revo when you tried this setup a time ago was there any wobble in this setup. even if slight wobble is there any. the reason i ask this is because i made a similar setup but i used a Emaxx shaft and drilled a hole in the shaft that sticks out of the transmission for the revo slipper pads. The way i drilled the hole i have exactly 3mm gap between the slipper pad (with fins) and the motor mount (BTW i am using the same motor mount). i used a piece of heat shrink and attached it to the outer shaft to make the slipper plate slit snug on the Emaxx shaft because the 6 sided hex like shaft is slightly smaller than the revo shaft. In my setup i am using all the same stuff as yours except i am using the Emaxx locknut and Emaxx shaft. My setup has a very tiny side to side wobble and i was wondering if i do change to your setup will that eliminate this problem. also will this minute wobble affect my car in any way.
