Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
B15
01.02.2008, 07:42 PM
Did you ever figure out anything for the brakes? I want one of these things, bad. I would want to do an hv setup, probably on an airplane controller, so I would run the mechanical brakes. You can just double them up, correct? Or if you swap to the center diff, you could use the buggy brake setup. Ill probably end up using a center diff and doubled up front discs with a single rear.
