david lamontagn
01.04.2008, 10:19 AM
Originally Posted by Blunten View Post
I'm having a problem installing a 46t kyosho spur gear onto the center diff. The spur wont go on flush with the diff case even when i try to force it in. Am I suppose to cut a piece off of the spur gear to make it fit?
Blunten
I have the same probleme when i've mine, and i've grind a little bit the diff cup with a Dremel tool and i fit perfectly.
