knotted
01.12.2008, 07:07 PM
Just started my build and wanted to let people know that a Neu 1521 will fit. Just add a frame spacer under the 4 motor mount bolts and it will lift the motor high enough to clear the rear part of the frame. And of course some Dremel work on the front mount for the 4mm screws the Neu uses.
ID:	3761   Click image for larger version
