Brushless Pinion and others.
Vrooom666
Brushless Pinion and others. - 02.16.2008, 01:52 PM
I am not sure if i am in right section but here it goes
1) How long is Mod 1 pinion is, the one that are sold on this site? (as in length wise)
2) Would carbon Fibre motor mount plate be good alternative to alumiumum for heat dispensation ?
I hope someone can answer those question.
rschoi_75
Certified Spaceball
rschoi_75's Avatar
02.16.2008, 01:55 PM
1) I get 12mm for the length.
2) no, aluminum is a better conductor
rcm xt8
rcm xb8
rcm crt.5
glassdoctor
TEAM FUSION
glassdoctor's Avatar
02.16.2008, 04:31 PM
My motor mounts are made with carbon fiber. It's great for strength and stiffness, but of course it does not conduct heat very well. Aluminum is a good heat conductor. And I have nothing against alum mounts... I just happen to have some good scraps of very strong CF and I like working with it except that it dulls tools really fast.
But... imo it doesn't matter that much. If you want to draw heat off the motor you can put a fan on it and also have it touching the main alum chassis. (could even use thermal paste etc..)
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
