dirt101
dirt101's Avatar
02.22.2008, 08:10 AM
im in the same boat. I think 2200k/v with 5s is just going to be faster than I want. I used to run 1668k/v(10xl) and it was about all I could handle. but Im still going to get it. Im just going to gear down as much as I can without buying another pinion.
17/40 with close ratio 2nd(locked)
used to run 17/36 wide with both gears.
jhautz
jhautz's Avatar
02.22.2008, 08:54 AM
heat is one problem, but if that doesnt get you the reduced run time of the high reving motor will. Just try and finish a long main on the high rpm motor.
Guys... If its not available there are other motors out there. Yes I know nobody wants to drop the cash on a Neu if theMMM motor will work, but if the controler wokrks as advertized we are still way ahead. I'm sure the lower kv motors will eventally come.
to make it...
or break it...
Silent...But Deadly
