MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
02.24.2008, 10:45 PM
30wt or 35wt seems to be fairly normal (30wt stock). I'm running 30wt at the moment with silver springs but I do want to change that a bit. I'm thinking 35wt in the rear at least. It also depends on how you are mounting your shocks too. If you are mounting the bottoms out at the wheel the 30wt might be perfect. Mine are currently mounted in from the wheel (irc kit) and I am waiting to move them out before I start playing with spring rates and oils.
