cooling fans for mm?
big greg
cooling fans for mm? -
04.30.2008, 09:55 PM
anyone know where to get em, or what ratings i should look for, also just tie it in to the ubec?
big greg
2
bdebde
That's All Folks!
04.30.2008, 10:04 PM
I use a 12 volt 25mm x 25mm x 10mm fan hooked up to the battery wires right at the circuit board, keeps the wires short. You can find them on ebay pretty cheap, I got 3 for $5, I still have 2 spares.
Ve8 - MMM, Neu 1509/2.5y, 6s
D8T - MMM, Neu 1515/2.5D, 6s
Muggy - MMM, CC 1520/1Y, 6s
SC10 4X4
bdebde
Find all posts by bdebde
3
big greg
04.30.2008, 11:46 PM
so even with the pack volts at 16.8 there ok?
big greg
4
bdebde
That's All Folks!
05.01.2008, 01:12 AM
yep, most have a pretty good voltage range (16-18 max). you may run a little over speed and shorten the lifespan, no biggy for a cheap fan.
SC10 4X4
bdebde
Linear Mode
Switch to Threaded Mode
