bl-is-future
bl-is-future's Avatar
05.13.2008, 07:24 PM
Are you sure the Flightpower 6s 5000 pack will fit? I don't have a Savage, so I have no idea, but I just want to get an idea what the biggest size battery that will fit in it will be...
God point just checked and it will just barely fit. I have the FLM chassis as you can see form the pics earlier. FLM also includes spacers you can add another 3.8 mm to the width of the truck chassis. The width is 44 MM with a smooth can motor. The length is up to 175 mm and height is really doesnt matter as long as it stays in the truck. Take a look at the pic.
The battery measures : 166 mm x 44 mm x 54 mm
NOTE: the 44mm is if i ground the motor fins down. the fins are 3mm deep and the chassis to the edge of motor was 41mm. If you run a larger pinion your will have more room. OR use the 3.8 mm spacers FLM provides. I plan to get a Neu smooth anyway so this is not an issue for me.
