9xl on 4s lipo
dpb318
9xl on 4s lipo - 05.14.2008, 04:10 PM
Ive been reading a lot and i think ive narrowed my choices down, im thinking a 9xl with a TrueRc 4s2p 8000 mah pack....would the 9xl be a good choice? Its only for general bashing, no racing, how will the 9xl on 4s compare to the stock K4.6?
Also, im thinking of running the mm with a ubec, would it be worth going to the mmm or will the mm handle bashing ok on 4s
What gearing would anyone recommend (im using the FLM forward tranny kit)
By the way, this forum is great.
DiFabio42
05.14.2008, 04:15 PM
I say get the MMM. It can handle up to 6s lipo and I think 16 NihM Cells.
The MM can handle 3s Lipo and 12 Cells.
05.14.2008, 04:22 PM
The MM is a solid 4s controller, just disable the BEC and use an external one. Although, the MMM would be a wise choice in the event you want to go up on the voltage in the future, or decide the MM is heating up too much.
BOOGIE444
05.14.2008, 04:33 PM
9XL on 4s will easliy out perform the K4.6, or really any nitro engine of that matter.
dpb318
05.14.2008, 04:57 PM
that sounds good, i think im going to go for the mmm just to be safe, id rather not risk it
how much run time should i expect with the 8000 lipo
Edit: and what would be good gearing
BOOGIE444
05.15.2008, 09:44 AM
Run time depends alot on gearing, having said that you should at least get 20min on the battery. Although the feigao might get too hot for that much continous running, make sure you get a rc-monster heatsink clamp. I am thinking a 20 tooth pinion would be about right with that KV of a motor, just watch your temps and see what gearing works for you. I bet its going to be some were between 18-22 tooth with that motor based on a 48 tooth spur gear.
dpb318
05.15.2008, 12:24 PM
would a 49 spur be a good start with a 20 tooth pinion, im going to be just bashing so less heat and lower top end is perfect for me (also would putting a fan on the motor heatsink help at all?)
just to clarify, a higher tooth pinion is less bottom end, more top end and a higher tooth spur is the opposite?
BOOGIE444
05.15.2008, 02:02 PM
49T spur & 20T pinion would probably be alright to start out with, just watch your temps frequently when experimenting with new gearing.
Larger pinion means more top end, smaller spur also means more top end / higher gearing. Personally I wounldnt bother putting a fan on a motor.
david lamontagn
05.15.2008, 11:33 PM
Hey guys, have you ever tried the K4.6, with good fuel like Byron Gen2 race formula, and a TSAIS T-32 tune pipe?????
I can telll you that's a screemer, and i'am realy impressed of this little engine.
I like brushless, but my Savage with the K4.6 impressed me each time i run it.
And you know what?? I've an RB Concept TM 928 with FLM extend low CG TVP on order, suppose to recieve it next wednesday.
BOOGIE444
05.16.2008, 09:01 AM
Yeah I have had a K4.6 and axial .32 in my savage with that same pipe. My 7XL on 4s blows it away, as does my kb45 8XL on 4s. The KB45 8XL on 6s is just show off power.
Even these cheap brushless motors have twice the acceleration and can be geared for higher top speeds because of the extreme torque the have. The only thing nitro has over BL in my opinion is smooth power band without having to worry about wheelies.
david lamontagn
05.16.2008, 04:45 PM
And don't have to wait for batt to charge, just fill up the tank and play
For bashing i prefered nitro, but for racing i realy love brushless.
BOOGIE444
05.16.2008, 04:52 PM
Yeah I forgot that one too
