Sammus
Sammus's Avatar
05.17.2008, 07:37 AM
Originally Posted by skellyo View Post
I ran through probably 20 packs with my RC18T before I stripped a rear diff. I was running a Mamba 6800 system in it using up to 2S Lipo or 8 NiMh cells. I didn't strip it until I started jumping it and landing it on flat ground more often than normal. The diffs are pretty darn tough if you shim them when you get them.
How often is normal? The only reason I have any RCs is for jumping, and although I set up and built landing ramps, there is still the occasional overjump.
It's the landing when the car nosedives mid air and you blip the throttle the level it out that kills the diffs, puts a lot of stress on them, even if its not a flat landing. I'd hate to invest in a new mini to find it not much better.
Has anyone had much experience with the MIP mlst f/r ball diffs? They look plastic in the photo but for $30 I'm assuming its metal. A pity tower doesnt sell them, I can only find them on evilbay, and even then no kind of rebuilt kits (Thrust plates or anything) even... so seems like a no go from the get go.
