Matthew_Armeni
Matthew_Armeni's Avatar
06.06.2008, 03:02 AM
I run both my MM's at 6s, one with a 1515 3d Neu and the other with a 1300 Medusa (both 50mm and 60mm versions) and also a 1500 Mega Motor. I haven't had any problems, but I am right at the components maximum voltage level and I don't run any cutoff. All the components on the MM are 26v and the caps are 25v so it really isn't recommended, 5s shouldn't have any problems at all though because you leave yourself some headroom.
  Send a message via AIM to Matthew_Armeni
tc3_racer_001
tc3_racer_001's Avatar
06.06.2008, 03:26 AM
keep in mind, some just wont arm... really good idea to get a few small lipos (if you have any) and hook them up to create the desired voltage and see if it arms, or cooks....
if it works, then add a fan and try it out off the ground. check temps then run it slowly around and just be generally cautious... 5s would be my max imo... but hey, its your controller!
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
speed demon
06.06.2008, 09:48 AM
Yes artur checked the whole arming thing all the way up to 6S so I think I'm good there. Thanks for the advice guys.
