What Neu Motor for CRT?
DiFabio42
What Neu Motor for CRT? - 06.26.2008, 03:32 PM
Hi Guys.
I might convert my Jammin' CRT to Brushless and screw Nitro for good!
1. What Neu motor is the best combo of Speed/Torque?
2. What Gearing is the best for staying cool and a good Speed/Torque Combo?
Thanks Guys.
06.26.2008, 04:32 PM
I'm a fan of the 1515 2.5D/F 5/6s on appropriate gearing - use brian's calc
DiFabio42
06.26.2008, 04:53 PM
Ok, Thanks.
What the Differential Ratio?
06.26.2008, 05:01 PM
Divide the diff ring-gear tooth count by the diff pinion gear tooth count.
And once you find out the tooth counts, let me know and I'll add it to the calc (note: I need the tooth counts, not the resulting ratio).
DiFabio42
06.26.2008, 05:06 PM
I can't find the Ring Gear and Diff Pinion anywhere.
skellyo
skellyo's Avatar
06.26.2008, 05:17 PM
I run a Neu 1515/1Y/F on 4S geared at 13:62.
06.26.2008, 05:19 PM
Did you try looking in the manual? Ofna is usually pretty good about putting tooth counts either in the exploded views or in the parts list.
43/13 Iirc
Yip - checked in manual http://ofna.com/pdf/34963-x1crt-pro.pdf Page 1 & 2
DiFabio42
06.26.2008, 05:56 PM
How fast is the Truck going?
cemetery gates
06.26.2008, 09:14 PM
I also run a Neu 1515 1/y/f on 4s geared 14:62, I would guess it hits 35-37mph.(this is in a crt)
Bye
DiFabio42
06.26.2008, 10:13 PM
Bye
1. How about on 6s? How much faster will it go?
2. Would the 1515/2.5d be faster?
Steve Krug
Steve Krug's Avatar
06.26.2008, 10:33 PM
Not Fabio..........lol
You've got to run lipos buddy.
Neu 1515/1Y/F on 4S is the fastest, cheapest route probably...
DiFabio42
06.26.2008, 10:39 PM
I am running Lipo.
What do you guys say?
1515/1Y on 4s?
or
1515/2.5D on 6s?
skellyo
skellyo's Avatar
06.26.2008, 10:45 PM
36mph according to my GPS. With the temps I get though, it could easily be geared for 40+mph and be within an acceptable temp range.
DiFabio42
06.27.2008, 09:00 AM
Not bad.
Is a 2.5D on 6s faster?
