MetalMan
MetalMan's Avatar
07.09.2008, 08:55 PM
This sounds like a diff shimming issue to me as well. You might want to pull the diff apart again, and put it back together without screwing it together, and check for the same binding. If it's still there, then move the shims around, or if necessary remove shims. Then add oil, and put the screws in.
