Gee
A Horse's Ass
Gee's Avatar
08.02.2008, 08:14 AM
Originally Posted by Patrick View Post
16mm bore means 16mm bore (the internal diameter of the shock body).
Kyosho does sell 16mm bore shocks for the st-r (I don't know if they're the same as the st-rr shocks), so the diameter of the CRT shocks shouldn't be a problem. http://www.amainhobbies.com/advanced...46-04&x=12&y=6
They say you need part number KYOIF346-04 to mount the bigger shocks.
Not sure about length differences though, I guess you'll find out when you get them.
THanks. Those are the same shocks that are on the st-rr I believe. They would be upgrades for the st-r. I can't remember where I read Jammin x1x/crt big bores would work but had it in my mind they were an alternative to the Kyoshos. I don't race and don't want to throw a 150.00 into a set Kyosho shocks.
The shafts are almost the same lenghts. The CRT have 3.5x65mm listed and the Kyoshos are listed 3.5x66mm. Only one has the lenght of shock casing. LO/L = 61mm/. Not to be confused wit = 61mm/
Length outside/Length inside ??
I'm guessing that's the length. I think they will work. One way or another. Need to get springs for it and the shocks spaces you mentioned Patrick. THanks for the input guys.
