08.24.2008, 02:45 PM
Originally Posted by ptt81 View Post
I dont understand, if you run 5S and set LVC to 12V, of course it won't run, am I missing something? doesn't LVC needed to be at least 16V for 5s, cut off at 3.2V each.
No, if the lvc is set lower than 3v per cell then it will damage the lipo. The only time you should have issues with the lvc is when you set it higher than the pack voltage. So a 5s fully charged pack is 21v, if you set the lvc to 22v it would have issues. 15v is the minimum setting for 5s lipo.
I suspect you may have firmware issues. Have you tried downloading 1.17 firmware into the controller? and then going back to 1.19 after that?
