09.14.2008, 01:04 PM
Originally Posted by phatmonk View Post
So I have a Tekno Slayer conversion a Slayer a MMM v2 a Motor now do I need a servo Y harness or a center diff conversion ?but the specs say on the Slayer that it has a forward only trans.Long story short is I want to go with a pinion and no clutch and use the MMM brakes.But on the otherhand the instructions for the conversion says I need a y servo harness when using the clutch setup.I have converted 2 1/8 buggies and a Losi 8T truggy those I have a good working knowledge of what to do but with the traxxas Slayer and 2 speed I need some guidance.Do I need RCM Motor mount?
If you plan to use motor brakes you will have to lock the 2 speed in 2nd gear. There is a sticky in the brushless section by BrianG that will show you how to do it.
The FOC kit that the slay comes with is also needed, which is good since you already have it.
