10.07.2008, 10:36 PM
It appears that the c50 gearbox models have a 6mm shaft. Otherwise the endbell still appearrs to be screwed on like the nongearbox models. Even if the screw pattern is different, it would not be difficult to drill and tap the front cover.
Specs: http://www.hackerbrushless.com/motor...spx?series=C50
No, I *think* that the exiting shaft from the gearbox is 6mm, while the actual motor shaft remains 5mm.
