10.07.2008, 10:44 PM
No, I *think* that the exiting shaft from the gearbox is 6mm, while the actual motor shaft remains 5mm.
Don't *think* to hard, you may hurt yourself... Don't see you doing too well on the reading comprehension part of the ACT either...
"C50XL Acro Geardrive Motors are available in 3.7:1 or 6.7:1 reduction with 8mm threaded shaft and Prop Adapter"
6mm shaft is for the input of the gearbox, thus it is the motor shaft diameter. Many motor mfgs do this with geared motors.
Also thse shafts are hardened steel, so no machining. You will be stuck with 6mm bore pinions...
