10.12.2008, 07:11 PM
I both a 4500 30C pack and a 6000 25c pack for my truggy. Performance wise I cant really tell a difference in either punch or pack temps. Ususally bith are comming off a long run around 110F. The 6000 just run a bit longer. If the 4500's work then the 6000 should be fine also.
BTW: I am using them in 5s configuration , but the cell comparision should still be valid even if you are using them in 6s config.
Ok, but do you think there will be any benefit going to the 6000 from the 4500? I feel my setup must be near the 4500 max due to the temps. I guess that I should drop gearing a bit and see if that helps any.
