E-fanatic
Brushless only!
E-fanatic's Avatar
11.21.2008, 08:12 AM
I dont belive it has the auto lipo but you can set the cutoff voltage for a 6s lipo. I had mine set at 15.4volts for my 5s lipos.
I was upset when I looked at the instructions and seen that it only went up to 4s cutoff and said that anything past 3s would void warranty. I talked to castle about it and he told me it only voids warrenty if you go past 3s while useing the internal bec(OK). So I told hin that it only had up to a 4s lipo cutoff and the box said that this esc could handle up to a 6s lipo????? He told me that the only way to adjust the cutoff past 4s was to use the castlelink and go to the custom cutoff voltage and ajust it there up to a 6s lipo. It does go up to 6s but I only was useing a 5s lipo. This esc didnt have any issues push a 9xl feigao in a 14 pound truck. If you plan on going with more power than that I would suggest putting a heatsink on it and/or a small fan!!!
The guy I sold my lst2 to runs the truck on 4s and the esc doesnt even get hot at all. We ran 4 5000mah 4s lipos threw here and the esc was 130*
