Rnemhrd
Rnemhrd's Avatar
12.07.2008, 02:51 PM
You will like it. I broke mine friday. About 20 out and landed bad. Boke the wing mounts and a rear hinge pin holder. Ordered some Kingheadz hinge pin holders. That may just cost me some a arms though. Just make sure the center diff oil is right. I use 30k and it seems good. Brushless needs a little thicker than nitro due to the instant tork they have.If it is to thin you will beat the front tires up quickly. Tell me how you like that battery after you run it. I'm running NeuEnergy 2s 4900s in series. 4s. I got the 2s so I can use them in my E Maxx and 3Ts but am thinking of getting some 4s packs.
riverat1540
riverat1540's Avatar
12.07.2008, 04:27 PM
i ran it today and its great. absolutely flies but needs heavier oil in the center as the fronts are doing too much work and its hard to even get the front end off the ground for long. didnt even get through a full battery before the pinion spun off and i coudnt find it so i will have to order another pinion before i can run more. ad yes it had locktite but i guess not enough. but it has lots of bottom end and is at least 50+ ran for about 15min and never got hot at all was running suprizingly cool.
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
