Originally Posted by FG101C
I don't like the motor mount. It looks nice and is a great idea for quickly changing the pinions and setting the mesh. One bad thing is it's so thick, it's really made for the Losi motor which a buddy and I found out are junk. If your motor has a really long shaft then it will work. The other thing is it really only lets you use a 45 tooth or smaller spur, unless you feel like figuring out a way to neatly shim it up. I have one sitting here that I just cant make work for me. The battery tray is nice though, provides a nice spot for the ESC to mount and routes the wiring under and over to the radio box.
I have a friend who swears by losi from the old xx and xxx days...and they were nice for back then.I had a few of each too. the Eight stuff he bought right into also,but now complains about gearing options and power system failures constantly and we don't run much any more cause he is allways broke down.(bummer)
When he is up and running,though, the losi looks good...just not too often.
