The medusa will run way cooler than either and be able to pull higher gearing than either without heating up as much. The Castle 36 mm motors have small rotors as does the velineon. A MM/Medusa combo will cost a bit more but will outlast either by far!
Thanks for the reply. So what gearing would you recommend? Something I am able to run 2s or 3s in without changing gearing.
